Search our IC Design Center for IP Cores and IC Design Related Content.
Or try an example search: AES128
Category: Memory Core IP Cores (44)
8/16/32 bit Configurable SDRAM Controller
Feature: • 8/16/32 Configurable SDRAM data width • Wish Bone compatible • Application clock and SDRAM clock can be async •…
License : GPL
Language : Verilog
DDR2-SDRAM Controller on Xilinx Spartan-3A
This project implements a DDR2-SDRAM Controller on a Xilinx Spartan-3A Board Function After a Power on : ================== 1. Init-Sequenz for the…
License : LGPL
Language : VHDL
16-bit SDRAM Controller Chip for Wishbone Interface
This IP core is that of a small, simple SDRAM controller used to provide a 32-bit pipelined Wishbone interface to a 16-bit SDRAM chip. When…
License : GPL
Language : Verilog
2Q Cache Strategy on VHDL
Overview I implemented 2Q cache strategy from paper "2Q: A Low Overhead High Performance Buffer Management Replacement Algorithm" written…
License : LGPL
Language : VHDL
Asynchronous Wishbone Compatible SDRAM Controller
SUPERSEDED BY HPDMC. Please do not ask me about this core! It is old and totally unsupported. HPDMC support, however, is available from the…
License : GPL
Language : Verilog
BRSFmnCE FPGA Implementation
This module implements a synchronous FIFO using Block RAM resources such as those found in SRAM-based FPGAs. This module has been used in several…
License : LGPL
Language : Verilog
CF Interleaver with 2 Interleaving Memories
Cores are generated from Confluence; a modern logic design language. Confluence is a simple, yet highly expressive language that compiles into…
32-bit CFI Flash Controller IP
CFI flash controller IP. Provides two modes of operation - simple (Wishbone bus straight through to flash bus, essentially, but with 32-bit word…
License : LGPL
Language : Verilog
32-bit DDR SDRAM Controller Core
The ddr_sdr controls read and write access of a programmable logic device to a single 256 Mbit memory device. The 32-bit wide user interface…
Implementation of DDR3 SDRAM Controller for FPGAs (Controller Core)
This is a controller core for DDR3 SDRAM. Default configuration supports one 64 bit UDIMM or SO-DIMM Supports DIMM sizes of 1GB, 2GB, 4GB and 8GB…
License : LGPL
Language : Verilog
DDR2 mem controller for Digilent Genesys Board
n/a
License : LGPL
Language : Verilog
FAT32 File System Parser
Please write a description of the project here. It is used as a MetaTag (search engines looks at this).
License : LGPL
Language : VHDL
Configurable Direct Mapped Cache Controller
This project is to develop a direct mapped cache controller for embedded applications. Key Design Features - Direct mapped with configurable…
License : LGPL
Language : Verilog
DPSFmnCE FIFO for UARTs
This project provides a parameterizable synchronous FIFO which uses LUTs instead of Block RAMs for its memory. The FIFO can be parameterized in…
License : LGPL
Language : Verilog
High Performance Dynamic Memory Controller (HPDMC)
HPDMC is part of the Milkymist System-on-Chip, the most advanced open source SoC for interactive multimedia applications. Fast DDR SDRAM controller…
License : GPL
Language : Verilog
Functional RAM Simulation Models
The simu_mem project provides functional simulation models of commercially available RAMs. Advantages of the simu_mem models…
License : LGPL
Language : VHDL
Generic FIFO in VHDL
A very generic implementation of a FIFO. Makes good use of VHDL transactors for data transfers. Does not support Wishbone yet, but it's planned.
License : LGPL
Language : VHDL
Wishbone Wrapper for Xilinx Memory Interface Generator (MIG)
Two WISHBONE wrappers will be developed for Xilinx Memory Interface Generator (MIG). The first is compliant with version B4 Registered Feedback…
License : LGPL
Language : Verilog
Generic Multi-purpose FIFOs in Verilog
Generic, multi-purpose FIFOs. Available as single clock and dual clock version, binary, lfsr, and gray encoded (dual clock only). All are…
Language : Verilog
HSSDRC IP Core Configurable SDRAM Controller
HSSDRC IP core is the configurable universal SDRAM controller with adaptive bank control and adaptive command pipeline. HSSDRC IP core and IP core…
Language : Other
