Or try an example search: BCD Adder
Here is proposed a method to implement short structured programs inside an FPGA. The novelty of the proposed method resides in that the commands…
n/a
Please write a description of the project here. It is used as a MetaTag (search engines looks at this).
Generic AHB matrix. It is a multi-master, multi-slave non-blocking AHB matrix with round-robin arbitration. Builds Verilog AHB matrices according…
Generic AXI interconnect fabric. It is a multi-master, multi-slave non-blocking AXI fabric with round-robin arbitration. Builds Verilog AXI…
Generic AXI to AHB bridge. Built according to input parameters: AXI command depth, data bits, etc. Supports error on illegal AHB bursts and AHB…
Generic AXI to APB bridge. Builds design according to required number of slaves, address decoding, AXI command depth, etc. Supports decode error,…
PSS (Programmable Supervisor for Systems-on-chip) is a soft IP core that targets to provide the basic means for conducting service operations…
This project is to implement a SoC of using OpenRISC 1200 and many open source IP cores from opencores.org on Nios II Embedded Evaluation Kit…
Asynchronous Spatial Division Multiplexing Router for On-Chip Networks Version: 0.2 On-chip networks or networks-on-chip (NoCs) are the on-chip…
The ECO32 system is a microprocessor system-on-chip, consisting of a 32-bit CPU and several controllers for peripheral devices (keyboard, character…
The GECKO system is a general purpose hardware/software co-design environment for real-time information processing and/or system-on-chip (SoC)…
AHB Protocol to Wishbone Protocol Bridge. Features - AHB 2.0 compliant - Wishbone B.3 compliant - AHB Burst NOT SUPPORTED - Fully synthesisable -…
Single channel 32 or 64 bit AHB master DMA core. Supports simultaneous read and write, command lists, peripheral control, timeouts and endianess…
The intention is to provide an easy way to configure, create and simulate a "complete" AHB system. The main block is the "AHB…
The Minimal OpenRISC System on Chip is a system on chip (SoC) implementation with standard IP cores available at OpenCores. This implementation…
The OpenCores aoOCS SoC is a Wishbone compatible implementation of most of the Amiga Original Chip Set (OCS) and computer functionality. aoOCS is…
A open source ARM vhdl model. The annotated vhdl source can be browsed here: http://cfw.sourceforge.net/build_html/vhdl/index.htm Features Note:…
Single channel 32 or 64 bit AXI master DMA core. Supports simultaneous read and write, outstanding AXI commands, command lists, peripheral control,…
This project implements the AXI4 transaction-level model (TLM) and bus functional model (BFM) in VHDL. Currently, only the AXI4-Stream Master…
