Search our IC Design Center for IP Cores and IC Design Related Content.
Or try an example search: AES128
Category: Crypto Core IP Cores (70)
Fast AES-128 Encryption Only Cores
Please write a description of the project here. It is used as a MetaTag (search engines looks at this).
License : Others
Language : Verilog
HIGHT Crypto Core
HIGHT Crypto Core
License : LGPL
Language : Verilog
Flexible Design of a Modular Simultaneous Exponentiation Core
Project information The Modular Simultaneous Exponentiation core is a flexible hardware design to support modular simultaneous exponentiations in…
License : LGPL
Language : VHDL
Floating Point Unit - An IEEE 754 Compliant
This is a single precision floating point unit. It is fully IEEE 754 compliant. It can currently perform Add/Sub, Mul and Divide operations, as…
Language : Verilog
Three Cores AES Encryption Algorithm
AES (Advanced Encryption Standard) is a specification published by the American National Institute of Standards and Technology in 2001, as FIPS…
License : Others
Language : Verilog
Simple AES (Rijndael) on Xilinx Spartan Series
Simple AES (Rijndael) IP Core. I have tried to balance this implementation and to trade off size and performance. The goal was to be able to fit in…
Language : Verilog
AES Encryption Algorithm 128/192 Bits
Here you can find two different implementations of AES encryption algorithm: - A 128 bits AES algorithm focusing on very low area applications. - A…
Language : Verilog
NIST AES - Rijndael Algorithm
The NIST has selected cipher Rijndael as AES on October 20, 2000 based on the combination security, performance, efficiency, ease of implementation…
AES Encoder and Decoder Modules
Consecutive AES core Description of project.. Features - AES encoder - 128/192/256 bit - AES decoder - 128/192/256 bit Status - Key Expansion added…
Language : VHDL
AES 128 Advanced Encryption Standard Algorithm
This Core implements the Advanced Encryption Standard (Rijndael Algorithm) according to the NIST standard as documented in FIPS-197. This AES core…
License : LGPL
Language : VHDL
AES Decryption Core for FPGA Implementations
While there are many AES cores around, this one is designed with LUT6 based FPGA architecture in mind from day one. The AES Decryption Core for…
License : LGPL
Language : Verilog
AES 128 Three Implementations in VHDL
Three different implementations of the AES-128 (VHDL).
License : GPL
Language : VHDL
AES SystemVerilog Behavioral Model
The AES behavioral model is not an encryption/decryption core, but a tool to facilitate the verification of AES IPs in HDL simulation.…
License : LGPL
Language : Verilog
128-bit AES Decryption Core
License : LGPL
Language : VHDL
AES Encryption All Keylength
Four stage pipeline design working at 361.890MHz on Xilinx's 28nm Kintex 7 speed grade 3 FPGA device. Calculating 4 blocks parallely,…
License : BSD
Language : VHDL
Pipelined AES 128 Encryption Module
The AES-128 pipelined cipher module uses AES algorithm which is a symmetric block cipher to encrypt (encipher) information. Encryption converts…
License : LGPL
Language : Verilog
Configurable Bluespec MD6-512
Features - Latency insensitive design - Should be portable to most bus architectures/platforms - Easily amenable to multi-clock domain extension -…
Language : Other
Pipelined AES Bluespec Cryptosorter
This IP core loads an unsorted, encrypted list of numbers from memory. It then decrypts and sorts the list. Sorting is acheived using a…
Language : Other
Avalon AES ECB Core (128, 192, 256 Bit)
General Description I know there are plenty of AES (Rijndael) implementations around. I created my own anyway because I was unhappy with either the…
License : BSD
Language : VHDL
B-163 EC Arithmetic
B-163 EC Arithmetic
Bit-serial multiplication on the NIST B-163 curve. This implementation utilizes DSP481E blocks (Artix-7 FPGA).
License : GPL
Language : VHDL
